Wandering Steering
Wandering Steering
Hello all,
I have a strange problem with the steering of my 02 7.3l F350 SRW 4x4. The alignment is dead on and checked three times over. It has 140k miles and all of the steering components feel solid with no play and the ball joints are new.
Symptoms:
1. when driving the and un even road is encountered, the wheels will track to the right and begin a swaying or fishtailing oscillation. it is more noticeable at higher speed and even more when towing a 3500lbs boat. To stop the action I must let my hand off the wheel and gas or it will get stronger and I am sure it would put me in the ditch.
2. the steering feels hyper sensitive an I have to over correct. If I correct to much it will begin to fishtail
3. On un-even roads the truck will want to drift to the low side. and then when correcting it will sometimes cause a fishtailing oscillation.
4. Steering sometimes feels spongy.
I had a master tech from Ford to a check ride with me and one of hic comment's was it could be a steering box going bad. I have also herd the same from other sources but I wanted to throw this problem up here and see if any of you have encountered this problem.
I am open to try any ideas.
Thanks
Symptoms:
Thanks
From what you've said, I'd lean towards the steering box as well. Just an off chance, I've never seen it on a newer Ford, check the steering box mounting point for cracks.
I've seen steering boxes go both ways, a slow degradation over time and a catastrophic failure. Of course the catastrophic failure had some other contributing factors.
eladnermai
01-08-2013 11:38 PM
Bigdaddybus
06-19-2012 01:00 AM
