Surging Idle and Sticky Throttle
I have a 93 F150 with the 351w (built up, GT40 heads, headers, and a cam for sure, possibly a 408 stroker kit as well) and a 5 speed with overdrive, 4X4. At idle the engine will consistently rise and fall from around 500 to 1000 rpm, and when you step on the gas the throttle will stick at anywhere from 1500 to 2500 rpm. I have a clean IAC sensor (I cleaned that myself) And when I have the engine idling, I can unplug the MAP sensor and the idle will immediately smooth out but it'll idle high at about 1200 rpm. I tried replacing the MAP sensor but same situation arises. I even tried the idle reset thing with the new MAP sensor but still, same deal. I also just recently noticed the EGR valve has been disconnected from the exhaust (plug in the header and EGR end is hanging open) and the vacuum port on the EGR valve has no line on or near it. I popped it off and the surface the EGR bolts to is completely flat, there's no hole for any exhaust gasses to enter if it were hooked up.
on
The sticking throttle could be a worn TB or a binding throttle cable but it should be easy enough to actually see if either of those parts are the cause of that problem.
If this motor does have all or even most of the upgrades mentioned there is absolutely no way it will ever run well on the original PCM, that combo needs larger injectors and tuning and that pretty much means it also needs a MAF conversion.
The new throttle body came sooner than I was expecting so I got the chance to clean it all up (including the IAC sensor again) and throw that on last night. At first it seemed to fix the sticky throttle issue so I went from there and started the process of trying to reset the idle. Left the battery unhooked for about 20-30 minutes came back started it up and left her run at idle for 20-25 minutes, came back and I still have the surging/hunting idle as before. But I also noticed that the throttle is still sticky but only after the engine warms up. Any Ideas?
Ford EFI 5 0L 5 8L MAF Conversion Harness Wire Plug | eBay
I found this... Would this be what I should be looking for, for the MAF conversion?
You didn't touch the throttle stop screw, did you? It's not an idle set screw, it's there to prevent the throttle blade from binding in the bore. It's pretty common to create a sticky throttle problem if you mess with that screw.
As for the MAF conversion, the easiest way would be to convert the truck to the Mustang A9L/A9P computer.
RARE Ford F150 F 250 F350 E150 E250 E350 Bronco MAF Mass Air Computer ECM PCM | eBay
on
Did you test out the throttle cable?
