Monitoring EGT
Old 05-21-2016, 09:10 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
I still like that Android thing that they have over in the 7.3 forum.
Lest see if I can find the link to it
I knew I had it and hope some will like what they read.
https://www.ford-trucks.com/forums/1...ssure-too.html
Sean <BR>
6.0L Tech Folder
Old 05-22-2016, 06:18 AM
Macrosill's Avatar
Macrosill
Macrosill is offline
I looked at the PLX Kiwi setup. You can add up to 32 additional sensors to it. But the cost adds up quick and I can see the wiring becoming an issue when installing those extra pid sensor boxes.
I "think" I am going to get the seperate egt sensor from Auber Instruments. This will be about 116.00. Then add a coolant filter for another 136.50 and keep using Torque Pro with my Nexus 7. I still won't get fuel pressure though.
My other option was getting the Dashoss kit for 360 or so.
Decisions, decisions, decisions.
edit: Sean, now I might have to get a new Android head unit instead of and egt and coolant filter. LOL
Old 05-22-2016, 03:26 PM
Rod Jr.'s Avatar
Rod Jr.
Rod Jr. is offline
Originally Posted by ultrasks700
Second the Edge CTS. The CTS2 just came out so you can nut up and buy that, or save a few buck and get the CTS. I added EGT and a backup camera to mine. If you hooking up trailers and stuff like that the back up camera is priceless. Wife don't even need to get out of the truck to help to line em up.
Which backup camera did you use? I could really use one for my trailer.
Old 05-22-2016, 04:11 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Sorry I made you think about spending MORE money.
Sean <BR>
6.0L Tech Folder
Old 05-22-2016, 04:26 PM
LCR's Avatar
LCR
LCR is offline
I bought one on Amazon for a place called TaoTronics for about $30. It looks like the full bracket one I bought is sold by Esky now.
Old 05-24-2016, 01:43 PM
Rod Jr.'s Avatar
Rod Jr.
Rod Jr. is offline
Which monitor did you use and where do you mount it?
Old 05-24-2016, 02:45 PM
diesel_dan's Avatar
diesel_dan
diesel_dan is offline
Brian you can save a few bucks and get a less expensive coolant filter from XDP -- it was the most complete kit out there when I got mine, you don't have to cut ANY hoses (well I did trim some off theirs, to make the install a bit tidier). It's $124.95 less 10% ($112.46 + $2 order processing I think) for FTE members using discount code DIESEL10 and that is including shipping...
Here's a link:
XDP 6.0L Coolant Filtration System XD143
Old 05-24-2016, 02:54 PM
brandonrr's Avatar
brandonrr
brandonrr is offline
Originally Posted by diesel_dan
Brian you can save a few bucks and get a less expensive coolant filter from XDP -- it was the most complete kit out there when I got mine, you don't have to cut ANY hoses (we'll I did trim some off theirs, to make the install a bit tidier). It's $124.95 less 10% ($112.46 + $2 order processing I think) for FTE members using discount code DIESEL10 and that is including shipping...
Here's a link:
This is the coolant filter setup i went with about a year ago. It was very easy to install and has filtered a lot of crud out of my cooling system. My delta stopped going up once i installed mine. I highly recommend it.
Old 05-24-2016, 07:29 PM
Macrosill's Avatar
Macrosill
I did not choose yet but will mst likely go with the Auber Instruments kit.
Here's a link:
I was looking hard at the Mishimoto kit for 139 from Ficmrepair.com but the XDP kit for 112 after the code seems like the route I will go.
Old 05-25-2016, 07:52 AM
JeremyXDP's Avatar
JeremyXDP
JeremyXDP is online now
SPONSOR
Here's a link:
Thanks guys! Give us a shout if there's anything we can help with.
__________________
Xtreme Diesel Performance | XDP
Call us @ 1-888-DIESEL4
Old 05-25-2016, 07:38 PM
Macrosill's Avatar
Macrosill
Coolant filter ordered!
Old 05-25-2016, 09:10 PM
diesel_dan's Avatar
diesel_dan
Tip for you, Brian: doesn't matter who's filter base, use plenty of teflon tape and tighten the fittings tighter than you would think. I had to redo mine twice (so that is 3 installs) before I tightened the snot out of the threaded fittings and it is still dry. Oh and put some silicone grease on the filter o-ring and just get it good and snug -- they can stick if dry...
  #28
Old 05-25-2016, 10:18 PM
Macrosill's Avatar
Macrosill
Thanks for the tips Dan!! Much appreciated.
  #29
Old 05-26-2016, 07:50 AM
JeremyXDP's Avatar
JeremyXDP
SPONSOR
Sweet! Thanks for your support!
__________________
  #30
Old 05-26-2016, 10:02 AM
Rod Jr.'s Avatar
Rod Jr.
Rod Jr. is offline
Sorry for the misunderstanding, I was inquiring about the backup camera and the monitor used, and its location inside cab.
Quick Reply: Monitoring EGT
