In my '54 F100 I have installed a series 400 power steering gear box from Mid-Fifty's using the stock pump which I believe is from the '80's (I think). When turning there isn't any power steering help with a very loud groaning noise. The belt is tight and not slipping. Any ideas will be helpful. Thanks.
You are not the first one having this problem. Sen the box back for warranty to cpp. You probably got shavings from manufacturing in the directional valve.
The groaning noise is the overflow valve in the pump that is open, or in other words the pump has reached the maximum pressure and then the overflow valve opens. This means you have some type of obstruction somewhere or a directional valve that is obstructed to move accurate (frome debris perhaps).
I have a friend here in Sweden that has had the exact same problems, I have tried to get a hold of him to see if he finally found the problem this winter. Sending back to state is not an option even if its a warranty. Shipping is a killer and CPP has not been that cooperative...unfortunatelly
No, mine has a skinny fill neck pointing towards the driver. I really don't know what year it is. I have contacted Mid-Fifty's and they are going to let me know, everyone is at the Nationals in Tennessee , so i guess I have to wait until next week for an answer.
Eaton P/S pump: There were two different styles of lids. The first type did not have the raised section for the dipstick, fluid would seep out.
The later lid has what is shown in the pic. On some cars with A/C, the can was remotely mounted on the left fender apron.
If the steel reservoir is contained within the P/S pump, it's the Ford/Thompson "pencil neck" P/S pump used on 1967/77 F100/350 & Passenger Cars.
