Bed floor question
Old 05-11-2016, 08:19 PM
schoo's Avatar
schoo
schoo is offline
Originally Posted by ben73058
Hey Schoo,
The "angle iron" stainless trim we got from Midwest Early Ford was
1.5 inches wide & 1.5 inches tall. We also used one of their bed wood kits - not sure
of the depth of the boards - not as thick as you would think - I'd say 3/4 in. at the most.
Our bed wood lay out looks exactly like 76-5.0's with the cutout area which is then hidden by the trim piece.
I hope that helps.
Ben in Austin
1950 F1
Thanks for the info did you cut out the axle hump or just cover it with the trim
Old 05-11-2016, 09:47 PM
ben73058's Avatar
ben73058
ben73058 is offline
Hey Schoo,
We didn't cut out the hump just cut around the axle braces
and covered it with trim. Our under bed supports were totally rusted
out so our entire under bed structure is new & was raised high enough to
clear everything but a bit of the axle braces.
Ben in Austin
1950 F1
Old 05-12-2016, 12:37 AM
76-5.0's Avatar
76-5.0
76-5.0 is offline
I spent $50 at the lumber store for my bed wood and notched it out with a skill saw. And yes, I am cheap. If and when I paint the truck, I'll upgrade to something pretty.
Old 05-12-2016, 06:33 AM
ben73058's Avatar
ben73058
ben73058 is offline
Nothing wrong with being cheap! Our truck is pretty but we use it as a truck.
I spent more on the bed than I wanted to .... would have been cheaper just to
replace the whole bed ..but we wanted to preserve it so that our truck was still from 1950.
It's so hot here in Texas & Oklahoma that pretty bed boards just get roasted -- good call using just treated lumber.
Ben in Austin
1950 F1
Old 05-12-2016, 08:27 AM
abe's Avatar
abe
abe is offline
One Meadow Green Owner
Received 2,616 Likes on 1,456 Posts
Be aware that the chemicals in treated lumber can corrode metal. There should be something between the treated lumber and exposed metal ornthe wood is not painted.
Old 05-12-2016, 08:41 AM
bhalemail's Avatar
bhalemail
bhalemail is offline
I was just going to say the same thing! ANY steel that directly contacts that pressure treated wood is going to be dissolved in short order. I'm not being critical of your setup, it looks nice but I would consider using regular "pine" instead of pressure treated. You could easily Thompson water coat the wood a few times before installing it. I jut know from experience that pressure treated wood destroys anything that is not stainless or heavily galvanized
Old 05-12-2016, 08:51 AM
schoo's Avatar
schoo
schoo is offline
Ben in Austin
1950 F1
I bought a new bed from northern classic for my 49 the old bed was rotted bad I had rebuilt the bed on my 64 I had $1000 in materials cost and maybe 400 hours in labor some time it's better just cut out the whole thing and buy new
My 64' slick
It's easier when the bed sets on top of the wood or wood slides under the sides
Old 05-12-2016, 10:39 AM
abe's Avatar
abe
abe is offline
Would Thompson's protect it enough or would you need paint on the wood to protect the metal?
Old 05-12-2016, 10:43 AM
abe's Avatar
abe
abe is offline
My 64' slick
You can buy a 53-56 F100 bed at Mid West Early Ford for $600. I picked mine up at Carlisle to save the freight.
Old 05-12-2016, 12:31 PM
76-5.0's Avatar
76-5.0
76-5.0 is offline
We'll see how bad the rust issue is with time. I'm leaving the strips unpainted so they will rust to match the rest of the truck. I've used treated wood back in the 80's in a W00 Power Wagon stepside. The rain and sun leached the chemicals out of the wood and it turned silver/grey like old barn boards. I'm hoping the weather does the same to this one. I bought this bed as a trailer for $150. With a script tailgate!
Old 05-12-2016, 12:57 PM
bhalemail's Avatar
bhalemail
I meant if using regular pine wood instead of pressure treated you could seal it, otherwise I'm not sure. Seems like the OP is ok with the PT wood and has used it before so maybe the contact on the outside is not as critical.
Old 05-13-2016, 11:46 AM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
56panelford is correct. The wood goes under the body side flanges.
I used Trex to prevent long term rot.
Then covered it with polished aluminum diamond plate.
Because I moved my gas tank out of the cab to the rear I just hinged the center Trex floor board for fill access. Easy . . .
  #28
Old 05-13-2016, 01:50 PM
76-5.0's Avatar
76-5.0
76-5.0 is offline
That's the later (late 1950 and up) style bed Pete, the 48-early 1950 was originally embossed sheet metal over wood and the bedsides were not smooth. The bed sides and front have a lip that the wood sits on. I have both style beds, but my fenders won't fit the later style.
  #29
Old 05-13-2016, 01:54 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
Sorry, got confused. I thought from your first comment that you had a '51+ bed.
  #30
Old 05-13-2016, 02:52 PM
76-5.0's Avatar
76-5.0
76-5.0 is offline
No problem. I should have put the year in the title.
ghalperin
02-06-2023 05:17 PM
rcav8or
04-05-2013 09:20 PM
Jdennis
01-17-2010 12:57 AM
midcal48
12-11-2007 01:05 PM
Spydycarnge
Paint & Bodywork
12-19-2003 07:40 PM
Quick Reply: Bed floor question
