302 is making a ticking sound??
If this truck has sat for a long while, something in the valve train maybe sticking. Have you changed the oil/filter lately? My 360 rattled for the first 4-5 times I started it, then it went to a slight tick. Later it stopped making any noise. Does the ticking increase in volume and speed if you increase the rpms? You could try some Marvel Mysetry Oil. You could also take that valve cover off and check the rocker arms for any excessive play then start the engine and check each one by putting slight pressure on each rocker arm to locate the noise.
Sealing the exhaust can just be allowing you to hear the ticking when you remove the seal you can't hear the ticking because the leak drowns it out? Just a thought I would look at the rockers as well that would be the hope full solution otherwise it could be as bad as something broken and bouncing around somewhere. Best of luck that's never a great feeling finding something else wrong
markjw
08-15-2005 08:58 AM
Sycostang67
01-26-2005 07:30 PM
