2016 F250 6.7 4x4
Almost sounds like a bad steering box it shouldn't get light. Unless your front tires aren't touching the ground. Then you'd have other issues i'd say.
Yes. Similar issue with my 2016 F250. Has the FX4 package and factory wheels/tires. I've had in 2 different Ford garages. 1st shop, 1st visit they told me it had aftermarket parts on suspension and they couldn't work on it. 1st shop, 2nd visit they told me there was nothing wrong with it but admitted it had a wobble. 2nd shop also recognized the wobble but said they couldn't find anything wrong with it.
I believe the dual wheel F350 & the F450 come with a steering stabilizer so I'm considering a Rough Country steering stabilizer kit. Any thoughts?
Yes it had Continentals, it is for sure an F250.
I have had it back to the dealership once, they did a quick alignment check (toe and caster are correct), need an appointment for a full check. They did say it sounded like camber might be off.
The full alignment check is next on the list, wanted to know if anyone else had the same issue before I went in....
