So I right now I have an Edelbrock 600cfm carb and a Edelbrock performer intake on my 351w and the intake came with a 4 inch 4 hole spacer. My question is since ive heard both sides from different people, should I use the spacer or not?
I run a 2" spacer on mine, ..... supposedly gives better throttle response as the spacer appears to increase the length of the runners,.... i. e. more volume.
Since there pretty easy to install, stick it in and run it awhile. If you don't like it remove it.
4-inch? The PO was apparently going for a tunnel ram effect. Generally not good for a street engine.
Concur with j0wilker... two-inch max. It's a 351W so a two-inch would be a hair better to assist in the TQ range.
Alright I think that's what im going to do. Why not haha, I went from a big block to a small block so mights aswell do some experiments with all this room
