2006 F150 engine coolant
Hey guys I'm a little bit low on coolant and I was searching around for it on the Internet and all I need to do is add a tiny bit but I'm not sure which one to go with ? And when I mean a tiny bit I mean it's right under the bottom Fill Line. I'm just confused on which one to buy
The pre-diluted is already mixed for you, so if you just need a little to top of the system, it's the most convenient since all you got to do is pour it in. The concentrated is a little more effort since you'll have to measure some out and put an equal amount of water to get the 50/50 mix. I'd go with the pre-diltued of its just to top it off
Resendiz
41
10-21-2016 12:46 AM
