1948 F-4. Driver build
#92
#93
Anybody have a spare original Ford passenger mirror arm and bracket? I actually need both sides . I stole one of my paneltruck arms for the driver side
#95
You need to look high.. and low... and uncover every salvage yard within driving distance and usually further.
Currently, I have one spare set of 6 - 5.25 x 22.5 - 5 hole rims but they will require some repair (pits welded and ground primarily) some have welding already started but will bed to be ground down
Nothing will be cheap, but it took me about 3-4 years to get 4 sets together.
Pm me for prices
Alternatly, call Chucks Trucks, we can order new ones (do NOT look original) or have 20" centers mounted in new rims, but that will cost significantly more and require shopping the centers
You will also need to find 9R22.5 tires... New ones of which are only available as import unless you can find NOS domestic
Similar can be done with 19.5" although the diameter is smaller and consequently your truck will go slower, especially with the low gears typically in F-5/F-6
Truckdog can help with part no's if that interests you but it's pretty obvious what your looking for.
#96
#97
Tires:
There's decent recaps for the rear avail for a real good price now on the "bay". Bought a set for this truck and while not perfect they are clean, soft and the recap was professionals done.
Do typical search sites for virgin fronts, they're out there and usually reasonable if your patient
#99
Sitting in DMV to get this heap registered.
45 mins to the information line, only 17 numbers from registering... Should only take 45mins to an hour !
Thanks Governor, better than the 4-6 hour it usually takes
Found the old registration from PO. Last registered in 1991, so probably when the gas was last filled ... No alcohol, no problems
#101
