292 Compression
Old 04-26-2016, 10:54 AM
JGuillen99's Avatar
JGuillen99
JGuillen99 is offline
292 Compression
Hey Guys, anyone know what the minimum compression needed to run a 292 engine is? I used the search feature but have found different answers. Some said 100-125 psi and others had trucks running on 70-80 psi. I've had my truck sitting for a long time and my compression is as follows:
1-70
2--80
3-80
4-90
5-95
6-90
7-75
8-90
Old 04-27-2016, 04:58 AM
Walston's Avatar
Walston
Walston is offline
Those are pretty low. A newly rebuilt engine is about 150. Will it run, maybe. If it has been sitting for a long time, you may put some MMO or ATF in each cylinder and let it sit for several days and if there are any rings sticking, that will help. How many miles?
Old 04-27-2016, 09:57 AM
cyclone-429's Avatar
cyclone-429
cyclone-429 is offline
Those numbers can be normal for an engine that has not run for many years. The rings & cylinder walls are very dry.
If you can get it started & running for even a few minutes, it will pump oil to all of the necessary places. Compression would then be much higher
Old 04-27-2016, 04:26 PM
JGuillen99's Avatar
JGuillen99
Well I got some smoke to come out of the exhaust today and a backfire or two but not much of anything else. I'm waiting for my battery to charge up and I'll try again. The engine turns easy by hand. The truck never really ran right since I've had it. I just recently did a valve job on it , I figured it was the least I could do for the old gal. Hopefully I can get her to fire up. I can't really afford a rebuild at the moment.
benbuilder
08-17-2019 07:08 PM
Chisum5013
02-04-2016 01:14 AM
Hammertime01
Missouri Chapter
10-01-2011 11:56 PM
geodiggr
12-02-2009 05:40 PM
Boxcar2282
Flathead V8 & Flathead 6
08-09-2006 09:09 AM
Quick Reply: 292 Compression
