Wheel and Tire Size for 1956 F-100
What wheel width/offset etc and tire size fits inside the rear fenders of a 1956 F-100? The rear axle is the stock Dana 44, stock suspension with re-arched and reverse eye leaf springs, stock drum brakes, and stock 5 on 5-1/2" bolt pattern (I'm a bit of a purist). The goal is to fit the widest tire and wheel combination inside the fender without doing any modifications. I know the width will be fairly limited and I'm okay with that.
Thanks,
Mike
Thanks,
Mike
Try this, it might be able to give you the info you need.
Rear Wheel Clearance Calculator - Mid Fifty F-100 Parts
BFOOTER03
03-07-2010 06:54 PM
keisha9
01-08-2007 09:51 AM
1968customcab
12-22-2005 07:43 PM
