1992 F-150 5.0 to replace 5.0 in a 1989 F-250
Hey all. I finally received my pull-out from the auto recyclers. It's a 1992 5.0 EFI from a F-150. It's going into a 1989 F-250 that had the same EFI engine. My question is does anyone know what changes I need to make on the new engine, (besides the norm of oil, Filter, Water pump, Etc.), to make this work? Any sensors, or wiring changes...Etc. Sure appreciate all the help I can get...Eric
on
Another thing I just thought of that may complicate your swap a little, Ford moved the IAT(Intake Air Temp) sensor from the lower intake to the airbox sometime in the '90s. Compare the two motors to see if this sensor is missing on the '92, if it is you will have to swap the '89 lower intake onto the '92.
Thank you for the heads up Paul. I Have a bit of time ( least wise the first of the month), till I actually do the swap, When I get my disability check to get all the other bits I need to finish getting it ready for the swap, hahaha...And hopefully the weather will cooperate for a couple of days. Thank you again. Eric
captain1997
16
11-15-2014 12:04 PM
HemiEater
13
11-30-2011 10:06 PM
lisagoud
02-22-2009 05:27 PM
