F1ZE-AA spring selection
Old 04-14-2016, 12:05 AM
htownoag's Avatar
htownoag
htownoag is offline
Ok fellas got the cam ordered. Went with the xe264h 35-349-8 comp cam again. It will go in a gt40 block with 80,xxx original miles. Got the heads off and now im going a different route than the recommended spring on that cam by comp.
Engine is bone stock except for the cam and
1.7 crane rocker arms.
The drop in springs if they are still available will they do me good?
Oh by the way the last combo i was using e7te's with the reccommended spring(987-16). 94 maf 5.0.
Am i lookin at .512. With that cam and rocker ratio.(1.7) or not? That cam says its designed for 1.7 ratio but in the cam specs it says..
"Advertised Duration: 264 int./270 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
Valve Lift with Factory Rocker Arm Ratio: 0.512 int./0.512 exh."
So if i am at 1.7 ratio is this correct
.512÷1.6=.32
.32x1.7=.544
(Lift÷1.6)=lift× 1.7= magic number?
Its late my eyes hurt. Proof read as much as i could.
Old 04-14-2016, 12:59 AM
Willz74's Avatar
Willz74
Willz74 is offline
You could also 1.7/1.6x.512=.544
Old 04-14-2016, 08:46 AM
Conanski's Avatar
Conanski
Conanski is offline
Yes it would be 0.544" lift with 1.7 rockers but the heads don't flow any more past 0.500" lift so using them would just put more strain on the valvetrain for no reason.. IMO.
Old 04-14-2016, 07:33 PM
htownoag's Avatar
htownoag
htownoag is offline
Well i had it on e7s. Im not a track person i just love my ford. Will drive it every day I just want some valve spring information to help me make an educated purchase...
Old 04-16-2016, 01:10 PM
htownoag's Avatar
htownoag
htownoag is offline
Any reccomendations
Will these be adequate for .544 lift? Had em on some e7te heads
Jrock909
01-02-2007 03:47 PM
imlowr2
09-24-2006 11:12 AM
luvinfords
04-21-2005 05:41 PM
j.m. ray
03-03-2004 03:56 AM
Quick Reply: F1ZE-AA spring selection
