high voltage
high voltage
This is probably a simple problem but so unsure. 2000 7.3 started and all is good at idle. Accelerate to 1500 RMPS and alternator light comes on and volt meter shows near full scale. Pulled back in to garage and checked with real meter. With engine off 12.3 volts. Start and at idle 12.8 volts. but when RPMs go up the volts at battery do the same. I got 18.3. If I put headlights and fan on full the light comes on about 1800 RMPs.
Replace alternator or is it a battery problem or something else?
Received 3,118 Likes
on
jdwxly
13
09-23-2019 09:52 PM
hillbillyjunkie
11-28-2009 11:57 PM
DIRTYSTEVEN
02-17-2008 10:14 PM
