Runs like crap
Runs like crap
Hey guys. I have a 92 F-150 with a 5.8 engine. About 4 months ago, I had to put a new engine in it. The mechanic putting the engine in got rid of the smog pump because he said it would get better gas mileage. After driving it for a while, it did great. One day it started skipping and I replaced the spark plug wires. It did fine after that until about 2 weeks ago I started it up, and it ran great until it got warm. It then started to idle rough and uneven and runs very rich. While driving it, it hesitates a lot. It also gets awful gas mileage. All the ignition stuff is new. New fuel filter. New EGR valve. New MAP sensor. New idle air control valve. I have no idea what to do now. Someone please help!
Sounds like you need that smog pump back!
He is a dirty liar. Smog pumps actually inject air into the catalytic converter during warm up to help get them up to the correct running temperature. Without a smog pump you'll be running rich during start up
Edit: cred to '89F2urd for correcting me
Since you mentioned an after-warm-up condition, it would appear that the EEC/computer now had full control (advanced to "closed loop" operation), so there is very likely a fault code.
For example, an oxygen sensor monitors exhaust and adjusts accordingly, you did say running rich.
Lot's of information in the archives about retrieving codes, related problems, etc.
It will *not* run rich all the time without a smog pump. It aids in reducing cold start emissions only, and that's it....the computer doesn't even know it's there, or not there. Mechanic is incompetent, agree with you there.
Checked codes
I had my mechanic run all the codes. I can't remember what they were, but he said they didn't have anything to do with why it was running like it is. He is as clueless as I am at this point. The truck runs great on initial start up, and then it "runs stupid" is what the mechanic called it. Any ideas of what it could be?
Cant tell you want is wrong but I do know the car runs in closed loop when cold meaning it is not reading the O/2 and stuff like that. So that should help at least point you in some type of direction. Check the codes and hopefully one of them is telling you a sensor is bad or missing. Should not have anything to do with your smog pump though or ignition components. If it is firing and running smooth when cold then you have fire and fuel. Something is telling the engine to change perimeters after it warms up. Could be the O/2, EGR, BAP/MAP, and as in my case when I first got mine running could be a vacuum leak somewhere that is only opening up after warm up.
