We Own Work: My 2017 Super Duty Experience
#917
That is so true. I really wish they would switch to doing it that way. I have a 14k dump trailer that I pull with my 11,200 gvwr f350 and I'm fine, but it's illegal to hook up to my 12,500 gvwr f350 drw. Very frustrating.
Also, I am just wondering if the OP had any chance to drive the 6.2 at all. It may have been talked about but I must have missed it.
#918
#919
I.E. My 11,200k truck plus 14k trailer equals 25,200. So I'm good. My 12.5k truck plus 14k trailer equals 26,500k, so I'm not good.
#923
#924
#925
Air dams are good to redirect air. I do not understand them on an FX4 truck, or any 4x4 which might, per chance, have an opportunity to wander off the road. It is bad enough to hear them scrape on the curb at the supermarket. Even worse is to realize you are plowing snow with a body part and then see it be the reason you are stuck in a mud hole....not sure they belong on a tough truck.
#926
#928
#929
I was working out the axle loading and GVWR margin for the F350 SRW and F450 options and think I may have solved the "why only 11,500# GVWR" mystery.
As near as I can tell, even the F450 weighs in the neighborhood of 9000# (subtract the max trailer rating from the GCVWR), even with the new aluminum body. The F350 SRW weighs around 1000# less.
If I'm correct about this, suppose they increased the F350 SRW GVWR to 12,500 to beat the Ram's 12,300# rating. With the 14,000# class 3 cap to the F450 weight and the 1000# increase in weight for the F450, you would get a only measly 500# bump in payload when upgrading from a F350 SRW to a F450 - not good marketing for their flag ship towing vehicle.
The new F350 SRW can have a 7230# RAWR and 5600# FAWR; 7230+5600 = 12,830# for the axle limit. Naturally, you don't want to push it to the limit there as you would have to have a perfect load distribution to not overload an axle. I suspect you could approach 12,500# without any problems though.
#930
I live on a dirt road (that's occasionally covered with gravel) so my truck tends to often look like that after it rains. I usually don't tear off the air dam or lose the wheel caps though but I won't judge.
