We Own Work: My 2017 Super Duty Experience
#633
[QUOTE=troverman;16425689]Anyone else notice this question went unanswered? It would be a shame if it stayed at 440 because we have seen plenty of propaganda that says "increased horsepower and torque" in the last few months.
#634
#635
[QUOTE=rocket_scientist;16426998]
Wasn't skipped on purpose. I'll say this, if you do enough internet detective work, one could possibly figure out half of the power rating. In my best Forrest Gump voice, "That's all I have to say about that till Monday."
As to the measuring, I came up with 59-60" to the top of the bed rail and 42-43" to the tailgate. Since the rakes are very positive, I would guess subtract a few inches for where the hitch will sit. Someone has a bed dimensions thread. We were similar in bed height measurements.
I think you will be alright with the 450!
#636
#637
#638
Someone else that went to one of the events measured at the wheel well on the bed at 58" (I assume with a tape). I was curious so I went out and did the same measurement on my 99' F250 7.3 CC 4WD and the height was 53.5". That's a pretty big difference.
I like it. 😁
I like it. 😁
#639
#641
I was thinking that Randy. I'm not sure if it would mess with the drive train geometry or if the previous gen 2" block would fit a 17? I certainly would do that though and it would save me lots of headaches. I just can't fathom the logic here. Raise the truck 1.5" due to the boxed frame AND go to 4" blocks. That's a 3.5" height increase over the current gen 450 and with the stiffer spring packs, I'd be quite nose high with no room for adjustment.
Maybe you could find out from your engineering contacts if the current 2" block would be an acceptable fit for the 2017 450 Josh??
#642
I hear you there. I remember when the '99 SuperDuty came out and the local ranchers/farmers had to have the dealer remove the 4" block for a shorter one, so that their brand new truck would work with their gooseneck.
#643
Thanks Josh for the information and new views. Eevery bit helps. Although each has his reasons to be concerned about the height be it too tall, not tall enough, appearance or functionality my concerns are these: I quite often load my Polaris UTV on the truck rather than trailer. It is a long way up the ramps now and additional inches will be that much steeper and higher. I can live with that. Loading the camper is another story. I worry that I will run out of travel on the legs of the camper if the bed floor is too high. And I wonder about the higher center or gravity. The farther up in the air the load is carried the more roll in corners. Time will tell if the improvements in suspension are not overshadowed by increase in height. And then too I wonder how much this will effect the manual loading of items in the box be they work, garden or play it is a long way up. The big cooler full of ice and beverages may need the forks on the skid steer, but in spite of these concerns I will be happy knowing this should be one of the best engineered and designed truck ever to come out ever. Thanks Dearborn and Louisville.
#644
#645
