Key on
03-27-2016, 10:50 AM
on
Key on
On my 03 f150 I need to have the key all the way on just to listen to the radio my question is will this drain the battery?
03-27-2016, 11:33 AM
Yes.
Anytime there is an electrical device in use the battery loses some power if the engine isn't running.
To get to the accessory setting on my 2003, I have to turn the key to the run position then quickly turn it all the way back to accessory.
03-27-2016, 04:45 PM
on
I can get so windows go down but the radio does not work unless key is on which will run my battery dead
03-27-2016, 06:07 PM
Are you able to get the key into the accessory position by turning it back instead of forward?
03-27-2016, 06:36 PM
on
I believe yes but the windows and work but not the radio that's mainly what I want to work.
03-27-2016, 10:16 PM
Aftermarket radio? If so, somebody wired it up wrong.
Leaving it in the "run" position drains the battery a lot faster than in the "Acc" position, since the entire electrical system is live when in "run".
03-28-2016, 07:35 AM
on
03-28-2016, 11:00 AM
on
I think I may have got it. Thanks.
03-28-2016, 11:40 AM
Quote:
Originally Posted by
racin
Mind sharing for others with a similar problem?
03-28-2016, 08:02 PM
on
Instead of turning it forward turn it towards you I just didn't go far enough.
Jftruck150
2009 - 2014 F150
10-06-2019 11:21 PM
Jftruck150
Electrical Systems/Wiring
11-27-2014 08:36 PM
fastwheeler
11-26-2014 10:09 AM
EXv10
03-04-2014 09:10 AM
mmhoward
02-05-2008 08:20 AM
