Have a 91 f150 with a 300 that runs rich. it runs rough/hesitates, idles rough/won't idle. I created a vacuum Leak by pulling a vacuum line off and that makes it run pretty good. replaced MAP and temp censors. Also it shifts hard, and pulling vac line off helped with that as well
Replaced fuel pump recently didn't change anything, have checked pressure regulator already, I'll pull the codes on Monday I'm at my in-laws for the weekend
