Diff Gearbox and tyre combo
Old 03-23-2016, 09:29 AM
willthesaint's Avatar
willthesaint
willthesaint is offline
Hi guys
I'm running a 289 with a C4 transmission using a jag 3.1 rear end.
I'm thinking of using an AOD but I'm not sure of what wheel and tyre combo would suit the AOD for the correct rpm .
Any help would be appreciated thanks in advance
Old 03-23-2016, 09:35 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,450 Likes on 1,397 Posts
Overdrive will give you about a 30% drop in rpm's, so you can figure out from what you're doing now what you will have with the same combo and od. If it's too slow, you could change gears to a lower (higher numerically) ratio.
Old 03-23-2016, 09:49 AM
willthesaint
Thanks wayne
LARIAT 85
27
08-09-2016 02:55 PM
LARIAT 85
16
08-17-2012 02:25 PM
straightarrow
06-13-2011 10:30 AM
davewave649
05-07-2011 05:30 PM
rocky50
07-15-2000 05:01 PM
Quick Reply: Diff Gearbox and tyre combo
