2013 Explorer BLIS and Cross Traffic Alert
I have a 2013 Explorer Limited with the Blind Spot Information System and Cross Traffic Alert. Quit working a couple of weeks ago after going through a small puddle. Not sure if this had anything to do with it though. The passenger side seems to work fine picking up vehicles as they come along side. The drivers side however doesn't pick up any vehicles and I get error messages when I start up the vehicle ever time. I think the sensor may be bad on the drivers side. Took it to a Ford dealer and they wanted to test the electrical system starting at the control module. Said they would charge me by the hour and it would be an all day job. If the passenger side is working and they are on the same fuse, wouldn't that be a sensor?
Well it could be except that its not just a sensor. There is a detector module on each side inside the rear bumper cover. This thing is a mini radar unit. I really doubt its an all day job - you might want to take it to a less greedy dealer. It could be the module, the wiring, or the main control module but the only and fairly easy way to find out is to plug a scan tool into the system and read out the fault code(s), then take it from there. The shop manual has a fairly clear troubleshooting procedure for this. If it is the detector module inside the rear bumper cover, it is necessary to use the diagnostic tool to download the configuration from the old module and upload it to the replacement. It probably takes a little while to get to the module to replace it but not all day!
Probably not. Most of the inexpensive scan tools can read powertrain, transmission and (maybe) ABS codes since there is a standard for those. They rarely read the proprietary codes used by each manufacturer for the various electronic "ghee-whiz" systems. You'll need a Ford scan tool for that. The same scan tool that's capable of programming the various replacement modules on the vehicle.
Take it to a dealer. Let them scan it and at least you'll have an idea how big a dent the repairs will make in your wallet. Doubt it will be cheap. Or live with it and drive like you used to before BLISS.
Personally, I've never found the system very accurate. While it almost never misses a vehicle in my blind spot it also rarely misses concrete road dividers two feet from the side of my car at 60 mph.
I doubt most independent shops would have the necessary equipment since the scan tool is Ford specific. They all have the generic ones for powertrain / transmission / ABS.
Unfortunately, you'll still need a dealership technician to check it out and repair it. But again - there's no way its an all day job. The hardest part would be removing the bumper cover and that doesn't look like a big deal.
Finally for this repaired at my local Ford dealer. A $2,000 repair that involved a short in the harness going to the unit and replacing the actual module behind the drivers side rear wheel. Forgot that I had purchased a extended warranty that covered everything, just a $200 deductible. Works perfect now.
robs01f250
07-26-2010 11:25 AM
