Need help finding capacitors
Old 03-18-2016, 05:17 PM
CrappyPappy's Avatar
CrappyPappy
CrappyPappy is offline
I have a 95 F250 4x4, my master cylinder was leaking and I didn't know it, anyway it dumped fluid all over the wiring harness and left me stranded I have already pulled the PCM and I have a cap that has been almost blown completely off the board the board looks to be OK other than ,that, but I can't seem to find where to get them, any help is appreciated.... Looks like a 10mf bluish green color.
Old 03-18-2016, 06:02 PM
jaagen's Avatar
jaagen
jaagen is offline
Amazon look for 10uf caps from United chemicon. Just did mine last week
Old 03-18-2016, 06:09 PM
CrappyPappy
Hey thanks a bunch
Old 03-18-2016, 06:17 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
10 uf and at least 63V rating. That's the factory spec.
While you are in there replace the other two capacitors:
47 uf 25v
Old 03-18-2016, 06:22 PM
CrappyPappy
Yeah thanks, I was planning on doing all 3 just so I don't have to worry about it again
Old 03-18-2016, 07:18 PM
subford's Avatar
subford
subford is offline
You could also try Digi-Key:
Old 03-18-2016, 07:23 PM
CrappyPappy
I found they have 10uf at radio shack but they are rated at 50v anybody know if these would be OK?
Old 03-18-2016, 07:32 PM
subford's Avatar
subford
subford is offline
No, as it has to be 63 Volts or higher in case you have spike that high. I think 63 volts is too small as a the voltage spike can go as high as 100 volts if you disconnect the battery while the engine is running.
The 10 @ 63 is in the incoming power line circuit to the computer.
Old 03-18-2016, 07:35 PM
CrappyPappy
Ok thanks, wasn't sure, in that case I'll just order online
robin1t2002
18
04-10-2012 08:15 AM
rich250
12-24-2007 03:55 PM
Bulldog187th
Electrical Systems/Wiring
02-17-2004 07:52 PM
ncalsurfer
05-06-2002 05:10 PM
Quick Reply: Need help finding capacitors
