Replace my 17 yr old springs or air bags?
New camper is a bit more of a beast than the old, so pondering my options. Keep in mind I have a 2WD.
I talked to Jr at ATS about new rear springs and he recommended some replacement C codes that are rated about 800 lbs more per spring than stock and will raise the rear 2 inches or so over stock. I have no idea how saggy my springs are compared to new, but they are 17 yrs old and have bounced around for 160K.
My other option would be air bags. My goal is to level the truck with the trailer hooked up. I've never had any of the infamous wander and have been very happy with how the truck handles towing anything I have put behind it with the original springs. I do already have the RAS system and a Hellwig sway bar.
Springs will be a bit more $$ than air bags, but that's not really a factor. It's a tank of gas difference. I'm leaning towards springs, but I'll be happy to listen to my FTE brothers.
Opinions?
Opinions?
Opinions?
Opinions?
Eric, for starters make sure your RAS is set to the higher setting (quarter size spacer if I recall)...
I have all of the above, what I like about the Airbags is I can leave very little air in them and it does not effect my ride. With my setup I sit about 2inches higher in the rear and if I need to tow I can get an additional 2 inches with the airbags.
Unless your Ex is a dedicated tow vehicle I would just do bags. If it's a dedicated tow vehicle do both. I think there's plenty of room in that new garage for either project.
I have the bags they do help with the squat but not control. I feel like the springs would be a better option. Personally I will have the Modified C codes and Shocks at my door when I get in from off shore. I have a question for you I cant remember is there any blocks under our 2wd rear springs? If there is and if the new springs give me to much lift i will pull out the block if possible or add a spacer to the front coils. I am watching the $4000 excursion thread to see the results they have with new front coils and spacers.
this confuses me,
the correct air bags for the intended load will allow you to adjust a vehicle to a level ride height by increasing the spring rate. that is the "control" for which they were intended.
air bags are ideal for towing simply because they allow for a lower spring rate for Daily driving without a load and increased rate for loads.
this confuses me,
I get it, (sort of anyway.....) based on my experience towing heavy with the stock springs. Back then I had some damned scary rear steer going on due to the stock springs wrapping and twisting in all directions. I have not used air bags on EX either with the stock springs or the upgraded B codes so I don't know what the changes with them would feel like, I understand that the bags are air springs (I have used bags and full air ride in other vehicles and uses) and will help support the load but I don't know how they would impact the unwanted movements back there under heavy use.
spring wrap is caused by torque and is really only a issue under full throttle when you first get moving, or panic braking situation where the rear tires are skidding or almost skidding can also cause enough axle wrap to be a problem... but axle wrap does not cause "rear steer" unless you have worn out bushings in the eyes or shackle.
obviously I have not seen your setup but I'd wager a fair sum that the scary steering was not caused by "wrapping and twisting" the more likely cause of that was weight distribution and understeer that is made worse by the *** down posture.
Somewhere I have a few pics of the towing setup with the stock springs and old TH, I'll have to look for them after we get home from this trip.
At that time the WD hitch did have the front end reloaded pretty well (again I don't have those numbers here with me) and the rear still had a bit of squat, but the heavy TW from that TH was doing some serious pushing that the rear suspension was not keeping up with. The first tow after the spring swap was like driving different truck.
I've got a few projects I need to tackle on the EX. Bigger hitch bolts is the biggy, probably going to drop the tank while I am at it and change the fuel pump preemptively.
Eric, why did you wait until Tom @WE3ZS is driving to his spring break in TN to ask this question?
I would do the springs and then (if necessary) add the bags since you already have the rear sway.
I'm of the opinion that the lack of a block is why you rarely hear about a 2WD wandering or having the rear move around as much with the stock springs. I'm no engineer, but just looking at any sort of block, it seems like it will increase the leverage of the spring in unwanted directions.
Looking at the stance it has now, I don't think I would like it sitting 3 inches higher in the back. That would obligate me to replace the front springs and maybe a leveling block.
I'm wondering how worn out do springs get in 17 years and 160K miles. They seem OK, aside from more squat than I want with 1000+ lbs on the hitch. Off the bump stops in the front by 2+ inches.
Now I guess I am back leaning towards bags. I'm still listening to feedback.
that's why air springs are a sweet setup on the fly adjustability.
I agree that air bags are a great addition to the suspension on a rig that hauls or tows heavy, I have used them in the past on other vehicles.
Since Eric isn't having any of the issues that I had with my stock setup then I think bags may be a good choice for him. Especially with a RWD EX, so many of the heavier rear springs from the trucks will give a lot of rake and raising the front of the RWD rigs to match can get pretty involved.
my therory on why you don't hear about 2wd Ex wandering is 2 fold, 1: they do not share the same marginal caster setup and leaf spring sag as the 4wd and there are just fewer of them to hear about when components do wear out.
blocks do increase the leverage the axle places on the leaf spring which under a full throttle launch will induce a bit more spring wrap but I doubt you would or could notice any difference in axle wrap between no block and a 2" block, maybe if you were drag racing you would get more wheel hop off the starting line. maybe.
