1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Weird smell from rear end.
Old 03-11-2016, 05:20 PM
Codyaye's Avatar
Codyaye
Codyaye is offline
So i have a weird smell from the rear end, and ive had it for like 2 months. when it first happened it was a sticking caliper so i replaced that, the passenger side. the passenger side wheel would get really hot but now there isnt heat on either side, it does smell stronger on the passenger side however. i wouldnt call this a burning smell, and to tell you the truth i have no clue what the smell is related to. maybe a burning rubber smell would be the closest i could put it at, if only i could transmit smells on the internet. im thinking it has something to do with the rear diff fluid, as when i checked it last it was really old nasty and gunky, it probably hasnt been changed in a long time before i got the truck. so i topped it off and decided i would drain the diff this weekend because i didnt have time last weekend. so please give me any ideas you have!
Old 03-11-2016, 05:23 PM
redford's Avatar
redford
redford is offline
Received 1,565 Likes on 913 Posts
Are any of your brake rotors real shiny? If you have a sticking caliper, the associated rotor will be buffed to a distorted chrome shine.
Old 03-11-2016, 05:34 PM
Codyaye's Avatar
Codyaye
Codyaye is offline
nope, none of them seem to be shiny too me
Old 03-11-2016, 07:38 PM
firebirdparts's Avatar
firebirdparts
firebirdparts is offline
The lube in the rear end has a distinctive smell, which you will be very familiar with after this weekend. Burning brake lining material also has a distinctive smell.
Old 03-11-2016, 07:51 PM
cferguson77's Avatar
cferguson77
cferguson77 is offline
Anything stuck to the tail pipe? Trash, plastic, small rodent?
Old 03-11-2016, 08:39 PM
davester250's Avatar
davester250
davester250 is offline
do you have drum-style parking brakes in the rear [inside the rotor hub]? it could be the inside seal is leaking diff fluid and if the parking brake is set tight, it could be doing this...
Codyaye's Avatar
Codyaye
Codyaye is offline
Firebird, thanks for the info. I didn't notice anything wrong with the brake lines however but the gear oil thing may be right.
Ferguson not that I noticed, I looked it over multiple times for a possible leak that was dripping and hitting the exhaust creating a burning smell.
Old 03-11-2016, 08:41 PM
Rongold's Avatar
Rongold
Rongold is offline
STRANGE SMELL
Sounds like you have a rear wheel hub seal that is leaking. Check the inside of both rear wheels for an oily, greasy condition. It's not a hard repair--8 bolts to pull the axle shaft and a special socket to turn & remove the adjusting nut for the rear wheel bearings. Once familiar with the process, it's a 30 minute job. Let us know what you find.
RON
Old 03-11-2016, 10:21 PM
Codyaye's Avatar
Codyaye
Codyaye is offline
RON
Thanks for the info Ron, I'll definitely check for that tomorrow after work! I'll let you guys know if that's the probelem!
Old 03-11-2016, 11:56 PM
wrvond's Avatar
wrvond
wrvond is offline
I get weird smells from my rear end too. My wife is always complaining but really, it's her cooking that's causing it!
Old 03-12-2016, 05:22 AM
Poncho450's Avatar
Poncho450
Poncho450 is online now
First thing I though of when reading the title of the thread.
Old 03-12-2016, 05:00 PM
Codyaye's Avatar
Codyaye
Codyaye is offline
LOL i didnt even notice that, nice one guys
Old 03-12-2016, 07:36 PM
ligito's Avatar
ligito
ligito is offline
I was too polite but I thought about it.
Old 03-14-2016, 11:05 AM
redford's Avatar
redford
redford is offline
This is one of those topics that you can only discuss on an automotive forum.
bbender85
13
03-10-2015 07:47 AM
mgmoore7
12-25-2012 10:13 AM
YOMAN
2004 - 2008 F150
04-04-2010 04:43 AM
b4hntn
1978 - 1996 Big Bronco
13
07-01-2007 07:26 PM
Quick Reply: Weird smell from rear end.
