Winch Mount...
Winch Mount...
Installed the Rough Country winch mount yesterday. One hour, by myself. Used a floor jack to lift it in place.
Only problem was removing the plastic molding which came in the spot the fairlead will be. Just a small rectangular plastic molding with a couple of bars down the middle for looks. It had two screws on top edge, and two pushpins on bottom , but also was molded with two catches on each side on the back I did not see. When I figured it out, and squeezed with just my fingers, little too hard and snapped one catch on each side. They slide into a slot and catch but wont be doing that ever again. Oh well.
As for mount, solid and easy to install. I used hand tools as the air gun would only hit one of the bolts for the front tow hooks. The other was blocked by plastic molding. No big deal.
Hidden Winch Mounting Plate for 09-14 Ford F-150 Pickup [1010] | Rough Country Suspension Systems®
Close up of holes on mount. Wet from a wash
Poor picture of stock tow hook two bolts that are reused and one new bolt and flag nut which is further back. Flag nut is just a nut on a long stem to hold and position since you can't get inside the frame to hold it. If you look above tow hook, inside frame to the right, you can see the very end of the flag which the nut is secured to on other end. This allows something to hold to position the nut while bolt is inserted in the boxed frame. Pretty easy to use. Three bolts to frame on each side.
The winch is a Smittybilt x2o comp 12k with synthetic rope. Amazon says it weighs 63 pounds. I think less, like under 50. The synthetic rope is reported to be 1/7th the weight of steel cable, and the reason I picked it. Also easier to use and an aluminum hawse fairlead also weighs less than a steel roller fairlead.
In measuring bumper before and after I had less than 1/4 inch sag to the front. I photographed it and compared both, no noticeable difference.
Amazon.com: Smittybilt (98512) X2O Waterproof Synthetic Rope Winch - 12000 lb. Load Capacity: Automotive
Went out on Easter to an empty lot and pulled brother in laws Jeep with it. Had to pull in with 1000 pounds pressure to wrap it on spool tighter and place the "guard" on it. The guard is for abrasion to protect the synthetic rope. Spooled in perfect under load and no problems. So easy I think I might have done something wrong!!!
BIGTRUCKBIGRV
1999 to 2016 Super Duty
05-29-2013 06:38 AM
