Rims
According to the parts book, the original 16" wheel B4C 1015A was used for both tube type and tubeless. Of course they would not have been rated for radial tires.
There's no reason you can't run tubes in the tubeless tires, it was a common practice in the 60's. I bought some 16" tubes from Walmart last year. Ordered them online and picked them up at the store. When I picked them up, the girl behind the counter was all flustered..."we can't mount or work on tires with tubes.." I got a kick out of that one.
Both the old tube type wheels and later tubeless wheels have the same outer rim profiles. They both have what's called a 5° bead seat, and a use variety of drop center rim designs. The only potential reason I see where the old wheels may not be ideal for tubeless tires is the risk of air leakage at the rivets or valve stem holes. Later wheels have the center disc welded to the rim rather than riveted. Using something to seal along the inner rivets could help, and naturally use of quality new stems. Stu
This is exactly where my original post was coming from.
btw: The 1966 FWD Olds Toronado was the first US vehicle to come with radial tires as standard equipment.
Pic: 7th entry under tubeless tire listing from 1964/72 truck catalog.
Thanks for all the replies. I am only use them to move the truck into and out of the shop. I don't care if they leak or not as I have an air compresser in the shop and a tank if if is our of reach of 200' of air hose. The tires that I am going to use are very worn. I saved them just for this.
Elmo
Elmo
1954F250
05-07-2008 03:59 PM
