Jesse
Old 03-10-2016, 02:20 AM
75Three90's Avatar
75Three90
75Three90 is offline
Jesse
I just got a new to me truck! His name is Jesse, he is a 1989 F150, 300I6, M5OD, 4x4, new fuel pumps, complete new brake system (including brake lines) rebuilt transmission, rebuilt transfer case, new TPS, new IAC, new O2 sensor, new cap, new rotor, new spark plugs (Motorcraft), new 8.8mm wires. Everything works including AC and cruise control.
When I got him the cat was blown up (literally chunks had clogged up the exhaust) I cut the cat off, extended the pipe to a flow master 40's series with a turn down dump under the bed.
Ever since I've got him he has ran rich and the CEL has remained on, I can't remember how to do the KOEO codes without the little scanner and I've never been able to function the search bar very well. So if anyone can teach me how to do the KOEO codes without a scanner I would appreciate it greatly.
Jesse has 140k on the ticker, has had Royal Purple oil in him for the past 10 years (I have a folder with all the maintence, repair records, receipts etc.)
Well that's about it for the ol guy, oh yeah, I only paid 800 bucks for him and drove him home. Thanks for reading, pictures soon to follow. Any advice would be greatly appreciated on the KOEO procedure.
Old 03-10-2016, 02:25 AM
75Three90's Avatar
75Three90
All four center caps and beauty rings are still on him!
Old 03-10-2016, 02:28 AM
75Three90's Avatar
75Three90
Clogged up and broken cat!
Old 03-10-2016, 02:55 AM
75Three90's Avatar
75Three90
Flow master 40 series with turn down dump
Old 03-10-2016, 05:45 PM
75Three90's Avatar
75Three90
They put coil over shocks in the rear
Old 03-10-2016, 08:53 PM
stak's Avatar
stak
stak is offline
very nice. a little body work and some paint and a little TLC will make it a grate sport truck. as for running rich i would start with the basic's / tuneup / check compression / vacuum leaks and so on.
Old 03-10-2016, 09:07 PM
75Three90's Avatar
75Three90
Thanks stak! I've covered all of that and still rich lol
Old 03-11-2016, 06:33 PM
ncranchero's Avatar
ncranchero
ncranchero is offline
Nice old brick! These OBS RCSB's are getting more scarce by the day.
Old 03-12-2016, 09:54 AM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
Google "pull codes obd1 f150" and the procedure will come up. You have to ground a terminal in the self test block that is located on the drivers side, attached to a rail by the air filter.
Why do you think it's running rich?
Old 03-12-2016, 10:02 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
Old 03-12-2016, 10:16 AM
75Three90's Avatar
75Three90
Thanks bud! I enjoy driving it!
Old 03-12-2016, 10:18 AM
75Three90's Avatar
75Three90
Thanks bud! Because I can smell it running rich
Old 03-12-2016, 10:24 AM
75Three90's Avatar
75Three90
Originally Posted by rla2005
Thanks man! I greatly appreciate it!
Old 03-22-2016, 08:23 PM
75Three90's Avatar
75Three90
A little update on Jesse, the fan clutch went out and had to cut it off. So I decided to go with an electric fan.
Old 03-22-2016, 08:32 PM
75Three90's Avatar
75Three90
I decided to hide the thermostat but in a location where i can adjust it
Quick Reply: Jesse
