LED Hood Light Mod
Old 03-11-2016, 10:53 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Great addition, Ken!
When I finally find time to finish updating the tech folder, this will for sure be added!
Stewart
Old 03-12-2016, 08:30 AM
BadDogKuzz's Avatar
BadDogKuzz
BadDogKuzz is offline
Ken how tall are them lights ??
Because after reading your write up and thinking about it I'm going to get a few of them KC lights for my underhood. I am thinking of also putting one under the cowl.
Do you think if you put one underside of cowl over the turbo it would be too hot?
Thanks again for sharing this with us!
Old 03-12-2016, 10:13 AM
DISLFVR's Avatar
DISLFVR
DISLFVR is offline
Locomotive breath
Looks great! Thanks for sharing.
Old 03-12-2016, 10:51 AM
woodnthings's Avatar
woodnthings
woodnthings is offline
They are roughly 1/2" tall. 0.530: per the spec.
Old 03-13-2016, 09:12 AM
Syncrowave's Avatar
Syncrowave
Syncrowave is offline
FWIW, I found a 10W LED floodlight on ebay here for $1.38 shipped. Looks like it'll take a little rigging (gotta make a housing of some sort) but you can't beat the price!
Old 03-13-2016, 01:24 PM
Y2KW57's Avatar
Y2KW57
Y2KW57 is offline
Received 3,349 Likes on 1,755 Posts
There is a certain precision and attention to detail that is the hallmark of just about everything that Ken (Woodnthings) does that is delightful. This craftsmanship is not only self evident in the content of his write ups, but also in the presentation. Ken, your contributions are more deserving than mere reps can reward... they merit real and genuine compliments on your style.
Old 03-13-2016, 07:52 PM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
Nice write up Ken. Yep added that mod to my list.
Old 03-13-2016, 11:36 PM
Tugly's Avatar
Tugly
Tugly is offline
List, schmist... mine are in a brown truck - along with parts to replace my battery clamps with the military style.
Old 03-14-2016, 07:30 PM
woodnthings
Thanks for the kind words. I really do enjoy working on and modding our trucks. I'm just happy to share the "how too" parts and am grateful for all of those who have done the same for me.
Old 03-14-2016, 08:14 PM
7.3Excursion4x4's Avatar
7.3Excursion4x4
7.3Excursion4x4 is offline
This is what I did. I used 8, 3/4" LED's and ran them to a toggle switch you can see next to the drivers side hinge. I originally bought 20 of them to put under the hood but I think 8 is plenty.
Old 03-14-2016, 10:11 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
Looks good, nice to have a switch. Question, do you get a code with your swamps IDM? Some say they do and I want to do this but won't pas smog here if I do. Sorry for the thread jacking.
Old 03-25-2016, 09:57 AM
Tugly's Avatar
Tugly
Tugly is offline
Uber-Geek enters the room....
I had a pair of KC HiLites Cyclone 1350s sitting on the bench, right next to my box of 12VDC power supplies and across from drawer with the Wago quick-taps. My shop at work has no windows, so I figured "Let's see what these bad boys can do".
No outside light, iPhony 4 camera with no flash.
Geek stuff: After this little test, I grabbed a 12VDC 1 amp power supply and hooked it up to the two lights. Once the halo-shaped sunburns on my retinas ebbed, I looked at the specs on the old anemic under-hood bulb
912 bulb:
1 amp
150 lumens
One of these KC HiLites:
0.4 amp
1100 lumens.
Over 7 times more light with less than half the amps - but 25 times the price. Still - I wanna see in there at night (and daytime), and dragging lamps and cords around gets old.
  #28
Old 03-25-2016, 10:51 PM
woodnthings
They are a nice and bright alternative.
  #29
Old 03-26-2016, 08:31 AM
BadDogKuzz's Avatar
BadDogKuzz
The more I look at these lights the more I dig them. I was hoping one of you guys might what the difference is between the 1350/ clear and the 1351/ defused is ? What would the benefit of a defused clear?
  #30
Old 03-26-2016, 08:56 AM
Jaime74656's Avatar
Jaime74656
Jaime74656 is offline
IIRC one is a frosted type clear and the other is clear see through
@7.3Excursion4X4: does not having the factory heat blanket thing under the hood effect anything? I'm trying to decide if I should replace mine or just toss it as mine is very tatty and I hate when things look all tatty and bad
Quick Reply: LED Hood Light Mod
