Removing efi on ford i6 300 1995
Old 03-09-2016, 01:08 PM
Sdean's Avatar
Sdean
Sdean is offline
I'm removing the efi on my truck and running straight carburetor with a new exhaust manifold. Do I have to replace the head or will it slip right on?
Old 03-09-2016, 02:09 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
NotEnoughTrucks2014 is offline
Here we go again!
No, you don't have to replace your head, but that's going to be the least of your worries!
Old 03-09-2016, 02:12 PM
Sdean's Avatar
Sdean
Sdean is offline
Originally Posted by NotEnoughTrucks2014
Here we go again!
So does that mean you have an answer?
Old 03-09-2016, 02:16 PM
Sdean's Avatar
Sdean
Sdean is offline
Here we go again!
What kind of problems have you seen?
Old 03-09-2016, 02:21 PM
NotEnoughTrucks2014
It has been discussed endlessly and recently. Search bar is your friend.
Just a summary, there will be more.
Fuel pressure will need to be reduced. Several methods here, not all are good.
You will need to change the intake manifold.
Do you have an electronically controlled transmission? No EFI = big headache.
All this to reduce performance and reliability? Not a good plan.
Old 03-09-2016, 02:30 PM
Sdean's Avatar
Sdean
Sdean is offline
It's a manual, so I'm pretty sure it's not electronic. I'm thinking either a Clifford or offenhauser. I'm aware of the fuel pressure. And no, in the end I don't think my performance will be decreased, quite the opposite.
Old 03-09-2016, 03:19 PM
6978sghfbjklgdfsjhkl's Avatar
6978sghfbjklgdfsjhkl is offline
I've done this
I should say I have used an EFI 300 with a carburator. Mine was a 91'.
It now has a Clifford intake with the EFI exh manifolds and is fed by a 63' Autolite carb. It runs great...It is however in my 86 Bronco.
I did rebuild it, and opened up the hole in the block for a manual fuel pump......I'll follow your progress.
Old 03-09-2016, 03:23 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
The answer is the head is the same for carb'ed versus EFI versions just like the 5L and 5.8L engines.
Sdean's Avatar
Sdean
Sdean is offline
It now has a Clifford intake with the EFI exh manifolds and is fed by a 63' Autolite carb. It runs great...It is however in my 85 Bronco.
I'm attempting the 'joy of six' project to hopefully get around 500hp. I'd like to eliminate the efi. Just making sure that it'll work before I get too far.
Old 03-09-2016, 03:25 PM
Sdean's Avatar
Sdean
Sdean is offline
Good to hear, that's what I needed to know. Thanks
Old 03-09-2016, 03:30 PM
if you do this
This is kinda true..but for the most part and EFI head has a different combustion chamber (faster burn), so tune accordingly.
As a disclaimer I wouldn't recommend removing ANYTHING from your factory approved "95" Ford product.
Old 03-09-2016, 03:33 PM
rla2005's Avatar
rla2005
Pardon my lack of fully making myself clear. From the aspect of whether or not a carb'ed manifold will fit on an EFI head, I correctly answered the OP's question.
It was my oversight to not mention there may be some differences internally.
The same can be said for the 5/5.8L engines but from the perspective of manifold fitment, there is no issue.
Old 03-09-2016, 03:34 PM
Sdean's Avatar
Sdean
Sdean is offline
I'm on ground zero right now, block and head going to machine shop tomorrow and then the shopping starts.
Old 03-09-2016, 04:45 PM
Conanski's Avatar
Conanski
Conanski is offline
Out of a Ford 300 6?
Old 03-09-2016, 05:01 PM
westcoasting's Avatar
westcoasting
westcoasting is offline
Lol, too funny!
Quick Reply: Removing efi on ford i6 300 1995
