Amp Meter
Amp Meter
Hey guys, I found out why my Stewart Warner amp meter doesn't work. The two leads are twisted back together loose under the dash. My question is which wire do I use to get the thing working correctly? Somebody told me to use the main power of the ignition. Another guy said to use any hot wire. Does the circuit have to be active? Or can I put it in line of a hot wire before the AC switch. By doing that will the amp gauge only work when the AC is on? Thanks, John
Amp Meter
John,
You really want the ammeter to measure the overall generator/alternator system performance, not an individual circuit. Here's a section of the 1956 wiring diagram. Yours should be very similar. Wire up your ammeter just as you see the instrument labeled "CHARGE" is wired. This method allows your ammeter to actually monitor the amount of current going into, or out of, your battery. Note that the current for the starter does NOT go through the ammeter since it's very, very large and you really don't need to meter to tell you that you're sucking a lot of juice out of the battery when you are actually starting the engine. You should use some 10 gage wires for your ammeter - pretty hefty stuff since your generator may produce 30 or more Amps on full charge.
old broke prospector
04-09-2013 07:43 AM
bryanknie
17
06-25-2002 02:33 PM
