Do I Need My O2 Sensor?
Hey guys, I just have a simple question to ask ya'll. So I have a 1989 Ford F-150 XLT Lariat Londbed Pick-Up truck with the Fuel-Injected 5.8 Liter 351 Windsor engine in it. The motor has 169,000 miles on it. Right now it is running straight exhaust manifolds with about a half a foot of exhaust pipe coming from each manifold. The truck only came with 1 oxygen sensor, which was an upstream O2 sensor that was located where both of the previous exhaust pipes connected together. I plan on getting an exhaust with an x-pipe and just having the O2 sensor installed there. My question is my check engine light came on. My two codes where "Insufficient EGR Flow" and "EGO Not Switching, Lean Exhaust (Bank 1). I am going to change the EGR valve and see if that helps, but is the engine code "EGO Not Switching, Lean Exhaust (Bank 1) caused by this O2 sensor not being there. I have no vacuum leaks that I am aware of. My other thing is do I need this O2 sensor? The only reason I ask is because the truck no longer has the smog system on it anymore and all of the smog vacuum lines and such have been capped off. Is there any point in having this O2 sensor? Please let me know guys! I'm heading out of town this weekend and need to know before I put my exhaust on there. Thanks guys!
on
The O2 sensor is the only feedback the EFI computer has to tell it how well it is doing at supplying fuel to the engine, it has nothing to do with the EGR system. So if you want something that could be confused with good fuel milage it must be installed in the exhaust and electrically connected but it doesn't need to see both sides of the motor and it's more important that it be close to the engine so I'd suggest installing a bung for it near the passenger side exhaust collector, do not put it further back where both sides of the exhaust come together.
on
So I can run true dual exhaust and it only has to be connected into one pipe?
Does it hurt to have it connected in an x-pipe?
mfp4073
1983 - 2012 Ranger & B-Series
02-21-2016 05:49 PM
