Best 4x4
Best 4x4
Ok so I'm stuck between a few choices of 4x4 vehicles. My first is a ford ranger fx4, doesn't matter year to me. Or a mini cooper countryman all4. I really don't know which is better I am going to be moving to wyoming pretty soon so I need a 4x4 when winter hits. I have also considered diesel trucks and a traditional f150. I have an 03 f150 currently but it is 2wd and i have got stuck in the mud last summer. Let me know what you guys think on what I should go with or if there is another vehicle that y'all have in mind, let me know and I'll do some research on it. My budget it probably around 15k, so keep that in mind. Thanks!
You'd be surprised what you can do with $15k on the used market today. You could get a few old rangers, or a very nice newer one with that much. Personally though, since you say you are moving to the northern climate, and you have a good budget, I wouldn't look at a ranger.
I'm a big believer in getting more for your money, and a heavy duty would do just that. The 4wd systems are much more durable and reliable. The engines are stronger so they can be more than enough for what you need, but always there when you need it. And the fuel tanks are bigger, the interiors are more comfy, the brakes and engine are stronger, etc.
A heavy duty would probably never need to be replaced unless you wanted to, and that's getting your monies worth out of a vehicle.
I live in Northern Colorado and have a fishing cabin in Wyoming so I take my 2006 FX4 Ranger up there quite a bit on some pretty nasty dirt roads. No problem. I would not think a Mini would be a great choice for Wyoming. Wind blows like hell in the winter and even if it snows a little bit you can end up with some pretty deep drifts, too deep for a Mini. I don't think you'd go wrong with a Ranger or and F150.
Kevin K.
Kevin K.
Kevin K.
Kevin K.
Here is an example that I found on google of what I want
The FX4 level II has (or did have) the Torsen limited slip rear diff. That's great for offroad or getting unstuck but I personally did not like it for turning and cornering on snowy/slushy/icy paved roads. My rear diff had to rebuilt at 190k miles, in hindsight wish I had gone with a remote locker instead of another limited slip.
Any Ranger w/4x4 is going to get you around just fine in snow assuming you have good tires. I think the LS diff is nice to have if you're in an offroad situation on uneven terrain or if you're trying to get unstuck. If you plan to be offroad then I would recommend a LS or remote locker, whichever model you get.
