Upgraded my truck to an F-350....
I've been driving a 2000 F-250 for almost 3 years, had 250,000 miles on it. But we wanted to upgrade to a larger and more comfortable ride. Finally pulled the trigger on a beautiful 2011 F-350. Man, this thing is loaded! Really nice truck, runs great, very smooth. My only concern is mileage. Anyone have any data on current mileage for this truck? Thanks.....
A lot of variables come into play in having a long lasting motor. If you maintain the truck like the manufacturer suggests I think the 6.7 would go 500k. My cousin has 190k on his 2011 f250 diesel and it runs great.
When we are talking about "deleting" on a Powerstroke 6.7L truck, it is more than just the EGR. It is the DPF, the DEF, and the EGR. Basically, this allows the truck's engine to run without regenerations, removes the possibility of a plugged EGR cooler, and no longer requires DEF fluid injection and refills. People choose to do this procedure because, generally speaking, it may increase the longevity of their engine, it may increase fuel economy, it may increase power, and it removes the possibility of expensive, emissions related failures down the road. As you can see, there are many benefits.
Resale value may suffer if factory emissions systems are removed. However, if you plan on keeping for a long period of time, that may be of little concern.
From my perspective, as long as all factory emissions systems are operating properly, I would leave them in place. If you are facing a very expensive emissions-related repair which would be eliminated by "deleting," then it might be a consideration if you lived in a state which was emissions-exempt.
For as long as its under warranty, and beyond that as long as its working properly and not requiring major expense repairs, I plan to keep mine stock.
However, once it is beyond warranty and if it requires replacing the DPF tube, there is NO WAY I will be paying $9k for a new DPF when there is a much cheaper alternative...
Just be happy you don't have to deal with any of these issues on your 6.2L. That is a great motor.
my recomendation is to just do the heavy duty service maint schedule. dont be one of those owners that try to get 10K miles between oil changes by spending oil change moeny on oil sampling test and trying to run their 5 year batteries for 10 years.
additives for fuel lubricity is important as well as checking fuel system water collection drains.
