Accessories staying on
So ive been doing my research and seems like a common problem, with guys radios windows and etc staying on after shutting the truck off and then opening a door. Well i feel mine is slightly different, it shuts off when i open driver door, but when i close it back it all come right back on. the key is out of the ignition. So i did some T/S and after waiting 30 and even today all day at work the radio and etc stayed on. I believe its the delay? but not 100% sure what do you guys think??
Ok so i believe a found the solution and hoping its what was actually wrong with it. So i was curious and pulled the rubber gromet back "the one between the cab and driver door" and was looking at the wiring and noticed a wire was cut in half i soldered it back together and taped it up and as of right now seems like its good to go the radio is now off.
Hope this helps anyone else that may have been having this problem
landscaper
1999 to 2016 Super Duty
03-20-2009 10:53 AM
Ford Fx4
Electrical Systems/Wiring
11-12-2006 12:37 AM
Ford Fx4
2004 - 2008 F150
09-20-2006 04:31 PM
