Windows quit working and radio stays on
My radio will also stay on after engine off and key pulled out … until I open a door.
The wires break inside insulation on drivers door bend point . You have to test each wire then splice in new sections using good flexible wire but of course the master control also get exposed to a lot of rain and use . You can cheaply use a aftermarket or clean up yours it can be done but I just replace .Clean your grounds in the left kick panel .
You can lift battery leads and ohm out each door wire using needles to pierce wires .Kick panel and door panel removal not that hard .I had to replace whole regulator assembly drivers door at one point .
Hesson81
07-22-2019 04:03 PM
Luzer27
1997-2006 Expedition & Navigator
12-27-2004 09:51 PM
