F100 Adjustable Drag Link - what parts?
I added a 3" drop axle to my 1956 F100 and noticed that the factory drag link is slightly too long. After looking into heating the curved steering arm, I saw this pic:
And found this pic:
Someone from this thread (https://www.ford-trucks.com/forums/7...oint-ends.html) mentioned Dennis Carpenter (Dennis Carpenter Ford Car, F-100 Pickup Truck, 8N, 9N Tractor and Cushman Scooter Restoration Parts) as a parts source. I could not find anything there that looked like what I was after. And the thread was a cold lead because it is pretty old.
Does anyone know how to find the pittman arm and adjustable drag (or parts to make it) link I need?
Thanks,
John
And found this pic:
Thanks,
John
Given how the pitman arm and steering box output shaft are made, its not possible to do that. It goes on one way only, no clocking it another direction. You can see what I mean from the image below. The shaft and pittman arm are machined with just a few teeth on the bottom that have to line up.
I'm subscribing as I'm interested about this as well. I've seen posts on the requirement for a modified draglink.
I bought front 4" drop mono springs, Toyota box, pitman arm and draglink from a guy that changed to a Mustang II IFS (told me he wished he hadn't spent the time and money because he didn't see that much of an approvement). The draglink he had was exactly like my original. I've been holding off installing the stuff because I can't find the correct shocks. He kept the QA1s he was running but when I go to QA1's site I can't find a shock with anything close to the travel that's left with the lowered vehicle.
Yes,
The original F100 shock didn't have much travel to begin with but when lowered it takes two to three inches away. I'll PM YOU a little PPT I drew up to record what you might need and the research I've done.
That's definitely not a stock drag link. Absolutely no reason for two adjusting sleeves on any drag link and we all know if they can save a penny they won't spend it. Did the original '56 drag link have those 'modern' type ends to begin with? I would expect to see the old style key-slotted joints.
Not sure if this is what you are looking for. We machined this between
centers left & right threads on the lathe. The problem is Origional Box
the ball & cup style has to go to a GMC spindle (disk brake) that has
a normal tie rod end. The pic shows it in place without the clamps. Threaded
so a good 2 inch adjustment can be made to center the box.
Thanks for all that have replied, I will keep trying to figure this out.
Hopefully we won't get chastised but it does go along with the lowering of the stock straight axle question of draglink under the "additional things needed"
Yes,
Yes,
I am still looking into this (slowly), but found this interesting article:
How to convert your 1953-1956 Ford F-100 Steering Box to Cowl Steering
truckdog62563
Ford Truck Parts for Sale
03-31-2014 08:26 PM
SuperDuty93
10-28-2012 11:54 PM
inlandsurf
04-30-2008 08:45 PM
