High pressure fuel system for F100
on
I used tanks from a '96 truck to fit my '78 when I used a DIY EFI setup on the 4.9L.
Also got familiar with the nylon lines as well and real cosy with the wiring... Like how to power two fuel pumps from the dash switch.
Right now thinking of using a urethane front tank and doing propane out back.
edit: Only issue I had to deal with is the Fuel Gauge and Sending Unit Resistances (Ohms) was different. I dealt with it by stuffing in modern gauges into the old instrument cluster with lots of dremeling, soldering, and JB Welding.
Another option is a fuel sump. You use a carb style electric pump (eg Carter, holly blue) to feed a frame rail mounted sump of ~1 qt. The high pressure electric pump is fed from the bottom of the sump. This is what I will do when I put FI on my '78.
Edelbrock and others also sell a complete sump with high pressure pump that can be mounted in the engine compartment but spendy.
Fin Harms
07-25-2018 06:14 PM
mustangmike6996
03-10-2015 09:58 PM
mando jake
13
05-11-2009 06:47 AM
danlee
05-07-2008 06:47 PM
