High pressure fuel system for F100
Old 02-18-2016, 08:56 AM
nlareau's Avatar
nlareau
nlareau is offline
I'm putting a 4.6l cv engine into my 77. What do you guys use for a fuel tank when you put in a modern injected engine?
Old 02-18-2016, 09:57 AM
ZarK-eh's Avatar
ZarK-eh
ZarK-eh is offline
I used tanks from a '96 truck to fit my '78 when I used a DIY EFI setup on the 4.9L.
Also got familiar with the nylon lines as well and real cosy with the wiring... Like how to power two fuel pumps from the dash switch.
Right now thinking of using a urethane front tank and doing propane out back.
edit: Only issue I had to deal with is the Fuel Gauge and Sending Unit Resistances (Ohms) was different. I dealt with it by stuffing in modern gauges into the old instrument cluster with lots of dremeling, soldering, and JB Welding.
Old 02-18-2016, 09:58 AM
COFLHTK's Avatar
COFLHTK
COFLHTK is offline
I am putting fuel injection onto the 400 in my 1978 F250. I am using the 38 gallon rear tank designed for the truck, but modifying it for an in tank electric pump.
Old 02-18-2016, 06:16 PM
Blue and White's Avatar
Blue and White
Blue and White is offline
Another option is a fuel sump. You use a carb style electric pump (eg Carter, holly blue) to feed a frame rail mounted sump of ~1 qt. The high pressure electric pump is fed from the bottom of the sump. This is what I will do when I put FI on my '78.
Edelbrock and others also sell a complete sump with high pressure pump that can be mounted in the engine compartment but spendy.
Old 02-19-2016, 07:11 AM
nlareau's Avatar
nlareau
nlareau is offline
I knew you guys would have good answers. Thanks a lot.
I think my easiest path is to look for a 90s F-150 tank (the small ones match dimensions almost exactly to the 19 gal F-100 tank).
dledm
44
01-08-2023 06:55 AM
Fin Harms
07-25-2018 06:14 PM
mustangmike6996
03-10-2015 09:58 PM
mando jake
13
05-11-2009 06:47 AM
danlee
05-07-2008 06:47 PM
Quick Reply: High pressure fuel system for F100
