1960 F100 Newbie
1960 F100 Newbie
I have just bought this F100 and it will be my first build. I haven't actually picked it up yet because I am driving about 12 hours to get it and im trying to find time. But I am super pumped.
I want a good daily driver with some power when i want it.
The guy thinks it has a 332 in it but it is disassembled.
I am thinking a 360/C6 or maybe even a 390/C6. What do you think? I am open to all ideas not matter what the costs or complications. Also, will the rearend hold up with a swap. I am actually not even sure what will or will not fit in it. Any help/advice is extremely appreciated.
Not much wrong with a 360 or 390/ C6, but they are thirsty! My thoughts are if you want good fuel milage and less maintenance why not go with an EFI and overdrive transmission setup Plenty of info out there no mater which direction you chose. Begin with the end in mind, and have fun doing it. This being your first rebuild you will be learning all sorts of stuff.
Good luck in your quest!
I have heard that from a old timer that I go to church with but I have never had a chance to hear one. But I am intrigued with it since I don't hear a lot about it. It would help set my project apart. Unless I'm just be naive.
Yup, mine has a T-98 4 Speed transmission. First gear is Granny gear. However, I added some horses to my engine (bigger valves, dual exhaust, 4 bbl Carb) and changed the rear ratio to 3.00 to 1 so I use the first gear as a real first gear and can cruise at 70 in 4th with no problem and pretty low engine RPM.
One of these days I am going to buy the modified bell housing from John Mummert and put a T5 5 speed in it.
I guess this is what I get for counting my chicks before they hatch. I contacted the seller of the truck to confirm the pickup time this Saturday and he told me someone just came and got it. I guess a guys word and agreement isn't what i was raised to know after all. Back to the classifieds and websearches i guess. hopefully i can find another 3rd gen f100 and continue this post/project soon. Thanks for your replies, it helped me get together a good plan of what i want.
on
Welcome to the "Orphan Years".
The 292c.i. Y-block was the Standard Engine for the F&M-100s starting in 1958.
Which was the Up-Grade from the 272c.i. Y-block that came Standard prior years.
The more one keeps it Factory, the More Value the Olde Girl will have, as there are fewer & fewer of them being left that way.
Alright thanks guys. I have worked on my grandpas 68 with a 390 and my neighbors that has a 360, that is why I was thinking about those two. I have never even seen a y block 292, which I believe was an option for a 1960. What are your opinions on that motor and the fordomatic trans?
