ICP Thermostat Aftermarket?
Old 02-09-2016, 09:03 AM
Eddie C's Avatar
Eddie C
Eddie C is offline
Any recommendation on whether to use aftermarket or OEM on both thermostat and ICP sensor for 95 f250 4x4 would be appreciated.
Local Ford-house wants 237 for an ICP sensor and 45 for a thermostat. I bought an aftermarket thermostat at O'Reilly about a year ago and don't know if it works correctly; gauge needle moves only about 3/8 of the way toward center when running, so I thought I'd replace it just in case
Old 02-09-2016, 09:07 AM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
I got both mine at Riffraff.
Old 02-09-2016, 09:11 AM
duck fan's Avatar
duck fan
duck fan is offline
Because racetruck
Here is where I got my Motorcraft thermostat, $31
Motorcraft Thermostat 94-95 - Riffraff Diesel Performance
They also have the Motorcraft ICP sensor for $137
Injection Control Pressure ICP Sensor 94-96
Old 02-09-2016, 12:43 PM
Eddie C's Avatar
Eddie C
Eddie C is offline
appreciate it. i saw where old bird recommended using fleet charge coolant on another link. I've never changed my coolant myself but plan to do it with this other stuff. I assume you're mixing the coolant with distilled water to get a mixture of 7.25 gallons half distilled water/ half coolant.
Old 02-09-2016, 01:13 PM
oldbird1965
That is correct!
Old 02-09-2016, 07:00 PM
Eddie C's Avatar
Eddie C
Eddie C is offline
thank you for the help
roller_steve
01-07-2017 12:05 AM
Danner717
01-13-2016 01:52 AM
Raleigh234
11-17-2015 06:43 AM
Major Marvin
34
02-14-2011 01:04 PM
waldreps
1983 - 2012 Ranger & B-Series
09-18-2006 11:33 AM
Quick Reply: ICP Thermostat Aftermarket?
