3.55 Elect VS 3.31 Non-Limited Slip
#46
From a Ford press release regarding the 2016 Pro Backup Assist:
Segment-first trailer sway control, 2009: The first trailer sway control for the 2009 Ford F-150, the Ford system senses differences in movement between truck and trailer, using the wheel brakes in both vehicles to counteract sway
This is from the '09 F150 brochure:
Originally Posted by 2009 F150 brochure
NEW TRAILER SWAY CONTROL is advanced technology that’s standard on all ’09 F-150s. A yaw motion
sensor in the AdvanceTrac® with RSC® (Roll Stability ControlTM) system can detect trailer sway through the
motions of the truck. AdvanceTrac can then automatically take countermeasures, such as selective wheel
braking and reducing engine torque, to help maintain control of both the truck and trailer.
#47
#48
What are the advantages and disadvantages between these features. This will be my first 4x4. I understand the 3.55 gear will be better for towing (torque) and get less gas mileage but am I able to lock the rear axles with a push button on the electronic? Would this also be what you would want if you were stuck in the mud? I don't think I will tow more than 10k so I'm trying to understand if I should order the mid trailer tow package ($895 MSRP) instead of the Max tow ($1195 MSRP) and keep the standard 3.31 with the 3.5 Ecoboost. Same questions about selecting a payload package.
3.55 Electronic Locking Axle Ratio
3.31 Non-Limited Slip Axle Ratio
You're confused because you're assuming that whole list of features are exclusive to the Max Tow package. Here's what the regular towing package includes for 2016 as per the order guide:
I'd agree with that. My E-locker is nothing but a $470 toy for me, I'd have never ordered this option. You only engage it when you're in a difficult circumstance, and it will automatically disengage over 20 MPH. Not saying I don't like it, but I don't think I'll really need it.
My point was that the OP stated in his post that he will not be approaching the limits of his truck. Your post and the one after seemed to recommend the max tow option as if he said that he was.
You know that I was one of the first guys here to get the EB with 3.31 axles and I've been amazed with the performance and the fuel economy. My truck has a 9200 pound tow rating. I've towed 8K in an enclosed trailer as I was helping a friend move some heavy stuff and felt like if I were to do this regularly, the 3.31's would feel insufficient.
#49
Thanks for the replies guys. I'm leaning toward the 3.55 gear ratio. I believe from the comments that the 3.31 would be ok for sure but just feel the taller gear would give me peace of mind when I really need it and not give up enough economy to make a big difference. Also, along with the 3.55 eco it might be a more popular combo to have for resale later.
#50
We may be going off on a tangent with this, but it's something worth clarifying if we can. This is my assumption, but I would welcome anyone who can confirm or correct:
- The Ford factory installed Trailer Brake Controller includes trailer sway control
- The Ford Trailer brake controller installed afterwards by your dealership will have trailer sway control
- An aftermarket brand of trailer brake control (like a prodigy etc) will not be able to use the trailer brakes as part of the sway control, the TRUCK brakes will still have stability control.
Am I right about that? If so, I can see some major value to the Ford brake controller.
#51
#53
#55
#57
#58
???’s about your truck
When you hen you look at your dash, do you just have the E-locker or do you have the trailer brake as well. I’m having a hard time finding a truck with what I’d like. Does the truck (with Elocker) need to have the trailer brake to have the Tow Package, or no
thanks for the help
thanks for the help
Ours is the 3.31 with the e-locker, and we have the larger differential. We do not have max-tow, as we only tow maybe 5-10 % of the time and none of our trailers are over ~~ 9,000 lb. We've had no issues.
We need the e-locker, and I've used it many times when we get into "gooky" situations. In fact, our baby is looking a bit like a mudder at the moment...
#59
You coulda just posted a new thread for this instead of digging up a 3 year old one...
Depends on which tow package you're talking about. Trailer brake controller is available as a separate option. My truck has the trailer towing package which included the pro trailer backup assist, but did not include the trailer brake controller- it was a separate option on the window sticker.
#60
Old thread resurrections are common when Google leads a new user here. There’s a lot of good info here though, so I’ll leave it.
Welcome to the forum boo7998. What year truck are you looking at? Since this is an older thread, some things have changed.
You may want to consider posting a new thread if you need help finding a specific truck’s specifications or need help sorting out option packages if ordering new.
OsbornFamily
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
09-08-2005 10:55 AM
aucatamount
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
13
08-17-2003 07:41 PM
