OBD1 location a 1995 f250 with the 7.3 Powerstroke diesel
Hello, this is my first post on the forum, so please bear with me. I just bought a 1995 f-250 with the 7.3, no leaks at all and drove great and the test drive. A month later, truck wont start unless you put your foot on the throttle, then it stalls out with a check engine light. So I looked under the hood for the obd1 port, couldn't find it. Then I looked under the dash and I found the main part of the obd1, but i cant find the separate return piece. Where is it? Also, why is there an obd2 and obd1? Do they both work?
Received 3,108 Likes
on
The following users liked this post:
Received 3,697 Likes
on
my '95 had the obd1 plug on the driver side fender. all of the '95 powerstroke trucks I have worked on had the obd1 plug on the driver side fender. I never tried to plug in to it and never inquired as to why ford put it there. they all also had the obd11 plug inside the cab on the passenger side. as also stated the communication channel has to be opened for it to work.
We have two '95s, and neither one has the OBD-I connector under the hood. There were a lot of changes mid-year '95; from 7-rib to 8-rib serp pulleys, from an external radiator overflow to an internal degas bottle, etc. I wonder if they discontinued the OBD-I connector with one of those mid-year changes.
on
yup, pretty sure. mainly because like is shown in Jose's post above, the EEC-IV, or pre OBD II link is under the hood near the driver side hood hinge, not under the dash.
and the connector under the dash he has plugged into the code reader looks just like the door chime connector in the 87 to 91 trucks.
