93 explorer wont start
Have you checked the fuse? If the fuse is good ( check with a multimeter if you don't have one replace the fuse) check for voltage (with the fuse out) at the hot side of the fuse if there is no power the easiest way to fix it would be to run a new wire from a power source with the key on only to the fuse.
Let me know how you make out.
womandriver
07-31-2014 10:25 AM
Khannink
12-03-2013 08:04 PM
maribou912
11-27-2013 03:28 AM
