19 code axel swap
19 code axel swap
I have a 1989 f150, 4x4, with a 19 axel code. The rear end is going out, lots of play on the pinion shaft which I hear is a common problem. My question is what year axels will fit in this. I am looking for a straight axel swap. Can I go with a newer model outside of this series truck (1987 to 1996) ? Mine has drum breaks, can I put one on that has Disc breaks without a bunch of modifications? Thanks for your help.
Anything else will NOT bolt in
Welcome to the forums.
Why not just replace the pinion bearings? If it is not howling yet the gearset likely isn't hurt.
I did my '89 2wd last winter. Same issue, you could wobble the pinion around. Never made any noise. I pulled ring gear and removed pinion, replaced bearings and put it back together. Still fine. I suppose yours is still an 8.8 out back?
Tectron1
12-18-2014 08:45 PM
crackerloco
02-19-2007 01:09 PM
