1970 f100 disc brake swap
Old 01-28-2016, 08:30 AM
jerrysoldtrucks1's Avatar
jerrysoldtrucks1
jerrysoldtrucks1 is offline
gonna do a disc brake swap. can i just use the i beams and spindles? with my old struts and springs? i know i need the steering linkage. what pitman arm? thanks from an old retired Marine. semper fi
Old 01-28-2016, 03:42 PM
jowilker's Avatar
jowilker
jowilker is offline
jerrysoldtrucks1 Welcome to and the Bumpside Forum.
Yes you can, but unless you are well versed I only recommend that you buy a donor 73-75 for the FE engine or 73-79 for I-6 or 302 engines and swap all the parts in, bolt hole exchange. I pulled my 76 donor along side my 66 dropped both I-Beam sets, slid the donor over and bolted it up on the 66. All parts needed are included. You will need to renew some parts and rubber items but everything will be there for you.
Play the game right and you can complete the swap in a couple weeks and have the donor removed in a 30 day cycle.
John
emeraldcoupe
Florida Chapter
11-30-2016 09:35 PM
tinman52
01-22-2014 04:35 PM
RangerJamesW
10-04-2007 08:25 AM
redavef100
08-06-2005 07:32 PM
msing
09-05-2004 12:15 PM
Quick Reply: 1970 f100 disc brake swap
