First time Powerstroke owner. 1995 Powerstroke 5 speed 4x4 139,000 miles. I am wanting to know what is causing the poor throttle response once warmed up. First thing in the morning when it's cold, it runs like a bat out of hell. As soon as it warms up it seems sluggish until the turbo kicks in. Any ideas ?
Z31freakify Thanks ! I have an OBDII on the passenger side inside the cab. I have hooked up my scanner with no luck. I was told I need to have the PCM reflashed to activate the OBD II port. As for the sticking IPR, that was my first thought. I would like to read the pressures first with a scan tool before I start throwing parts at it. On a side note where do I add my signature ?
Go to user cp and click on edit signature. I still cant figure myself how to edit mine ive tryed but my signature still doesn't show on the bottom of every post
A generic OBD-II device won't communicate with your truck, even if it's been flashed to activate the port. Chances are, if the truck was ever at the dealer, it has been flashed.
Just a shot in the dark but if it runs OK when cold and gets worse when warm, it could be your oil isn't the right viscosity for the fuel injection system. Unless it's new oil of the right viscosity rating, I'd try changing it, especially if it's time for a change anyway.
