adding upfitter switches to 2016
Patrick
Where is C-215 hidden? Ive pulled the lower dash panel out and cant find it, thinking of pulling the top half. I pulled the little tray compartment next to the center console and found 2 wires plugged into the back of it. (any ideas what they might be for?) It looks like on the picture I have it may be behind the steel bar in there. Thanks
The only panels I removed were the coin dish for the switches themselves and the one below the steering wheel, no wires involved.
I just completed my install this weekend by adding LED spots up front, wired to upfitter 1, and an LED aux reverse/work light wired to upfitter 3. I'm very happy with the results it was worth the twisting and turning under the dash.
This does not work on the 2016 models if it did not come with it. I just spent collectively over 3 hours on calls with Ford and the dealership. Apparently this was possible up to 2015 and that harness was located where TFLT says, but on 2016 Ford doesn't allow that unless it comes from the factory and doesn't even make it an aftermarket option like they did up to 2015. In fact Ford says that if it is attempted in 2016 it will void the warranty. I also asked about wiring the switches independently of the harness and they said they are not sure that is even possible. Why would Ford change this crap like this and the dealers not even educate the consumer. The dealership flat out told me that this could be done easily, now I find out it cant be done at all! The ONLY thing that may be able to be done according to the dealer, not sanctioned by Ford is to take the dash and instrument panel apart and "see" if there is a harness to plug into, but that is slim at best that it would be there. I even saw the wiring schematics for the 2015 and the 2016 that the dealer showed me and it supports what Ford said, the wiring schematics are completely different and that harness on the 2015, is NOT present in the 2016. Thought I would share.
SWITCHES CAN BE ADDED TO A 2016
The one post on here about not being able to add them to a 2016 is INCORRECT. I have a 2016 f250 XLT 4x4. I have added them. Total time 15 minutes. You need to purchase the switches, wiring, and the relays. The plug that the switches connect can be found by laying under the dash on the drivers side, look directly above the steering shaft you will see a white 8 pin connector approx. 1" x 2" it has a grey dummy plug plugged into it. remove the grey dummy plug this is where your new harness for the switches plug into. from there mount the relay box behind the lower dash cover just under the steering wheel. ( it is removed by lifting slightly up and pulling out.) I mounted mine right next to the trailer brake harness located on the left side behind the panel. Next you need to remove the coin slot. My truck has a center console so to remove the coin slot I lifted slightly up and used a flat micro screwdriver and slightly pried the bottom out. Then use a small coat hanger and feed it through towards the new harness. Tape the plug end for the switches to the hanger and pull them through. Connect them to the switches and push the switches into their new home. You will need to add a fuse into the factory fuse box on the passenger side kick panel in order for the switches to work. DONE
I appreciate you correcting my reply about the upfitter switches not working on a 2016 F250 XLT 4x4, that information that I provided was after speaking with 4 dealers over the course of 3 days. They are showing no parts available for these switches for the 2016. So can you please provide me with the part names and numbers that you gathered for the switches, relay and wiring for these switches? Ford does not list anything for the truck because according to them and even the lack of a 2016 wiring schematics the option does not exist for this truck. Thank you.
Swirches...
#28
Thanks, just looked again, they were just tucked in a pretty heard to reach place, looks nothing like this: https://www.fleet.ford.com/truckbbas...C-PTO_v1-0.pdf
#29
Upfitter switches are on my to do list. This thread has been really helpful. One question that you may be able to answer for me.....I have a XLT w/o fog lights. I'd like to add a 20'' light bar in the bumper opening. On the front frame cross bar, just under and behind the radiator are two capped off connectors. One has wire color yellow/black and the other is yellow/purple w/ a green tracer. Are they for fog lights?
