intermittent wiper conversion
Looked at the post for this, but my question is, I have a 1965 Ford F100 with 2 speed stock wipers now. I have an early to late 70's delay switch setup. How do i hook the switch up without changing the motor like the posts talk about? Wiring diagram.
Thanks for responding.
new member
new member
Welcome aboard.
Does your new setup look like this? If so, it should be plug 'n' play.
Unhook old wiper switch from dash panel
Pull out the electrical socket
Plug electrical socket into new delay switch into the end of the pigtail
Mount new switch into the dash panel
Find location to mount the delay module nearby (underdash)
Not positive about every 1965 or 1966. Works well if you already have the 2 speed wiper motor and the 7 prong switch. Others, I'm not sure about. Here's some good reading.
https://www.ford-trucks.com/forums/5...onversion.html
Originally Posted by TA455HO
...2 speed wiper motor and the 7 prong switch.
Applications: 1987/91 F150/350 & Bronco.
I had to shorten the shaft on my switch a little to use a stock looking ****. If you use the later year **** (same year as the intermittent controller) no modification to shaft required. I just wanted to use the period correct wiper ****.
FYI only.
PS James: I see these advertised on eBay all the time for around $35.
Rich
FYI only.
Rich
Originally Posted by James Western Canada
...and I'm guessing there is a high probability of the Econoline vans using the same switch/module as the F series??
Uh huh, guess again...
FOUZ-17C476-A (replaced E1UZ-17C476-A) .. Intermittent Wiper Governor / Marked: E1UF-17C476-AA / Obsolete
1981/91 Econoline (E150/350).
IICAP I believe that is correct.
John
