Greasing zerk fittings
I just changed my ball joints out on my 1990 f150 4x4. I am to the point where I have to grease the ball joints and my tie rod end because the pickle fork squeezed out a good amount trying to take it off. I have been trying to find something to tell me how to tell when I have enough grease. Which is basically my question. When do I stop pumping grease into the fitting.
If you have been in the slop with it, I'd definitely pump grease into them until you see fresh grease, that way you make sure that the joint has been "flushed" of any dirt, water or other contaminants. Normal street driving, that is probably not necessary, just pump till you start to see a little ooze out.
fightlivefree
01-05-2016 10:33 PM
Kwikkordead
02-09-2007 10:46 PM
